Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
Beam & Column Move
1 REPLY 1
TrevN
397 Views, 1 Reply
Beam & Column Move
So I've modelled in project a beam which has several columns attached to it. (Joined)
I now want to move that beam and columns horizontally.
I select the beam and columns (at this point they are neither a group or assembly) and move all of them horizontally.
When I do this some (not all) of the columns do not move as I am expecting. It seams their top nodes stay where they where and so the columns are now slanted.
All I want to do is move all elements, while maintaining their relative position to each other.
Why are they going all screwy?
Thanks.
1 REPLY 1
awes
in reply to: TrevN
Are your columns originally slanted columns? How do you move the structure? Are you only dragging the beam. Do you select all columns and beam? How are those odd reacting columns connected at bottom level? What happens if you group columns and beam and the move? Just some thoughts to begin with.
