Hi!
I have a problem in my Revit model.
Most of my floor plans are associated to a incorrect level and I don't know how to change it.
I'm currently unable to create new wall, ceilings, etc.
I can't create new floor plans because the model contain to much information already and will be imposible to re-drawing all the information.
Please help.
There are many things that may be wrong but mainly this is a view range issue. For walls and columns, make sure you are using height if you start in an architectural template and depth in a structural template. The level is an instance property so you can change it from there if needs.
