Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
Assign Rebar for 3D View as View as Solid for Rebar within a model group
5 REPLIES 5
marty
703 Views, 5 Replies
Hi All,
I have rebar placed within a model group.
This group is then copied about 1000 times.
I want to change the View as Solid setting for a 3D view without having to edit each group individually as this setting does not propagate to all other instances of the group in the model.
ie if it set in the group then this group is copied, the new group has it unchecked.
Hope that makes sense and hope someone can help.
Marty...
5 REPLIES 5
jad.dellel
in reply to: marty
Hello Marty,
Sorry for the delay, we created a case for you (case 07831260).
I will send you an email for more details.
Jad DELLEL
Sustainability Success Manager - Autodesk, Inc.
Jad,
Where do you guys publish solutions to specific cases?  I am interested in knowing the outcome of this issue.
In such case, we need more information from the customer.
After, if a solution exists, we will share it in the forum.
Jad DELLEL
wr.marshall
in reply to: marty
was this ever resolved, and what was outcome? As I have just run into this issue.
Please see my Revit idea: Rebar View as Solid per view (not individually) - Autodesk Community
Hi @wr.marshall
In Revit 2023, rebar is shown as solid in 3D views, when the detail level is set to Fine, so the other per instance setting is no longer required.
https://youtu.be/Jqyk25fAzEI
Ovidiu Paunescu, M.Sc. Str. Eng.
Sr. Product Owner | Autodesk Revit
These enhancements give you the ability of faster 3D rebar model navigation and increasing your productivity in detailing concrete structures
