i keep getting an error when performing "reinforcement code check" in revit. in short, revit fails to transfer data to robot. i've tried reinstalling revit and robot 3 times already. also updated dotnet. not sure what to do next. tested this with new clean projects. i searched the net about it but only found an old topic for version 2013 that was not solved : http://autodesk.lithium.com/t5/Revit-Structure/Problem-with-sending-data-to-Robot-using-Reinforcemen... . any help on this will be much appreciated. tnx.
here is the complete error message:
REX:
Engine version: 2014; Version name: ; Culture info: en-US
PLATFORM:
Win32NT Microsoft Windows NT 6.1.7600.0
SOURCE:
AREX
MESSAGE: (3/9/2014 10:53:44 AM)
Reinforcement export exception!: : Unable to cast COM object of type 'System.__ComObject' to interface type 'bcl.RCColumn'. This operation failed because the QueryInterface call on the COM component for the interface with IID '{CEE36FA0-885D-11D2-AF83-0080C86BDF8D}' failed due to the following error: Error loading type library/DLL. (Exception from HRESULT: 0x80029C4A (TYPE_E_CANTLOADLIBRARY)).; StackTrace: at REX.DReinfColumn.ReinfFactoryRevit.ExportToRobot(RobotImport import, RnfColParam RectColPar, RCAD_DB_Bar[] dbParm, RnfColReinforcement Colrebar, RnfColSteelElemParam SteelPar, Extension ext, Boolean IsReinfObject, Boolean _IsFreezed, Boolean _TransferGeometry, Boolean _TransferReinforcement, REXMaterialConcrete _ConcretePar, AREXRnfColMngr RnfMan)
at REX.DReinfColumn.ReinfFactoryRevit.OnRun()
DEPENDENCY: Autodesk.REX.Framework, Version=1.0.0.0, Culture=neutral, PublicKeyToken=51e16e3b26b42eda (file version: 2012.0.0.1769) | REX.Controls, Version=2014.0.0.2608, Culture=neutral, PublicKeyToken=null (file version: 2014.0.0.2608) | REX.Controls.WPF, Version=2014.0.0.2608, Culture=neutral, PublicKeyToken=null (file version: 2014.0.0.2608) | REX.Controls.Forms, Version=2014.0.0.2608, Culture=neutral, PublicKeyToken=null (file version: 2014.0.0.2608) | REX.Mathematics, Version=2014.0.0.2608, Culture=neutral, PublicKeyToken=null (file version: 2014.0.0.2608) | REX.Preferences, Version=2014.0.0.2609, Culture=neutral, PublicKeyToken=null (file version: 2014.0.0.2609) | REX.System, Version=2014.0.0.2608, Culture=neutral, PublicKeyToken=null (file version: 2014.0.0.2608) | REX.Service, Version=2014.0.0.2608, Culture=neutral, PublicKeyToken=null (file version: 2014.0.0.2608)
