Is there a way to see architectural partition walls (non structural) in Structural Revit? I know that if you change the discipline to coordination the partition walls will show. But is there a way to keep the discipline at structural and still see the partition walls?
No. If you want a "Partition Wall" to be visible in a Structural Discipline view, select the wall and check the "Structural" parameter in the Properties Palette.
This can be done for any wall type. If you don't want an Analytical Model for a partition wall, uncheck "Enable Analytical Model ".
Joe
