'Cause when you copy an arch wall, it's set to non-bearing, and structural
views don't show non-loadbearing walls. You'll probably want to modify the
walls' properties, and set the view back.
Kate Morrical
AutoCAD LT Technical Marketing Manager
wrote in message news:5920155@discussion.autodesk.com...
That was the ticket! Thank you very much...But, can you tell me why the
discipline matters? Seems like it should copy no matter what you discipline
is set to. Just doesn't make sense to me. Anyway, thank you again for your
help!
