Hello
I am a computer programmer attempting to apply a parameter to a relatively simple family so please forgive me for any ignorance 😛 Can you give me some advice on how I can apply a diameter parameter to my Pipe Family (the Family inherits from a Metric Structural Framing - Beams and Braces).
Below are images of my Family in its current state:
As you can see above I would like to apply a parameter called 'Pipe Diameter' that will set the diameter of the pipe. Can anyone provide advice on what steps I can take to achieve this?
Notes:
- Yes I am aware Revit has standard pipe families BUT I am writting an addin. And addins can only create pipes IF the user is in a MEP Project (in Revit 2013 this is solved in Revit 2014). So using standard pipes is not a solution to my question.
- The family was created by producing a Circular Extrusion in the Left view/elevation and then a Circular Void Extrusion. So maybe I can apply a reference line to the void extrusion then click that line and apply a parameter to it? Although I've tried this and it doesn't work but maybe I did it wrong?
Solved by conormccartney3897. Go to Solution.
