Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
Annotation lines are hidden
3 REPLIES 3
2327 Views, 3 Replies
Hello, look at this file. In the view "Fundamentplan" I got some annotation lines wich are hidden, but I have not hide them and I can`t unhide them. You can see them if you turn on the "Reveal Hidden Elements". What is wrong here?
I`ve tried to reduce the filesize but it`s still to big to attach here.
Eirik.
3 REPLIES 3
CoreyDaun
I've received your file via email. Looking at the View that you mentioned, I see that "HELP" you drew in Detail Lines that become visible in Reveal Hidden Elements mode. They are hidden simply because the "Lines" Category is turned off. Even though these lines are Annotation Lines, their visibility is controlled by the "Lines" Category under the Model Categories tab, in Visibility/Graphics Overrides.
Corey D.        ADSK_Logo_EE_2013.png    AutoCAD 2014 User  Revit 2014 User
⁞|⁞ Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate to further enhance these forums. Thank you!
Joe.Charpentier
in reply to: CoreyDaun
If you want to "attach" a Revit file to a post, the best solution is to put a link in your post to a file uploaded to Dropbox or an A360 account.
Both services (even at the free level) should have plenty of space for a Revit file.
Joe
Ah, thanks, I was looking at "annotation categories" in visibility/graphics to see if I could find something there. Great. Smiley Happy
