Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
Analytical Wall Reference
2 REPLIES 2
1186 Views, 2 Replies
How do I move away the analytical reference from a wall as presented in the attached picture?
Thanks a lot!
2 REPLIES 2
johnsobr
I suggest you set the Horizontal Projection parameter of the wall to the adjacent Grid (e.g. 2 or B). See my response to your [Wall Horizontal Projection|http://discussion.autodesk.com/forums/thread.jspa?threadID=711475&tstart=0] post.
Also check out Tools > Analytical Model > Adjust Analytical Model to make adjustments (e.g. moving the wall edge to the center of column) and Tools > Analytical Model > Reset Analytical Model if you need to undo the manual adjustments made.
Brian
Brian E. Johnson, P.E.
AEC Technical Specialist
Thanks Brian!
