Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
analytical problem with attached picture
3 REPLIES 3
amin078925
1036 Views, 3 Replies
hi everybody
i have a problem with anaytical issue , how can i make the anaytical beam concected to the edge of the column to be sure the load will transfer to the column plz find the attachment below
Tags (1)
3 REPLIES 3
abduallahadi
in reply to: amin078925
delete the column and draw it again
amin078925
in reply to: abduallahadi
it's not about deleting the column or not . the beam must connect in this way from edge of the column to the edge of other column
okapawal
By default the analytical beam position is ruled by auto-detect rules.  Beam node is automatically pushed to a column position. See image AM0.
If you want to modify AM position change alignement porperties for analytical element.
Depending on what you want to achieve:
- you may change the column posiotn, image AM1
- or change the beam position and adjust manually the second beam, see AM2 image.
- or maybe change the beam position and create rigid link between the beam and column node.
Waldemar Okapa
Sr Product Owner
