hi everybody
i have a problem with anaytical issue , how can i make the anaytical beam concected to the edge of the column to be sure the load will transfer to the column plz find the attachment below
it's not about deleting the column or not . the beam must connect in this way from edge of the column to the edge of other column
By default the analytical beam position is ruled by auto-detect rules. Beam node is automatically pushed to a column position. See image AM0.
If you want to modify AM position change alignement porperties for analytical element.
Depending on what you want to achieve:
- you may change the column posiotn, image AM1
- or change the beam position and adjust manually the second beam, see AM2 image.
- or maybe change the beam position and create rigid link between the beam and column node.
