I´m creating column over 2 levels and I would like to add a node at the intersection of the first floor and the column. There is a way to do this?
Attached the place where I would like to add the node.
Regards
In Revit, nodes are automatically created at the ends of linear elements or corners of planar elements. Therefore, to "add a node" you would need to split the column at the first floor.
Joe
Ok, so to export a structure to Robot. It´s better to have one column per floor?
