Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
Analytical Nodes
2 REPLIES 2
718 Views, 2 Replies
Analytical Nodes
I´m creating column over 2 levels and I would like to add a node at the intersection of the first floor and the column. There is a way to do this?
Attached the place where I would like to add the node.
Regards
2 REPLIES 2
Joe.Charpentier
In Revit, nodes are automatically created at the ends of linear elements or corners of planar elements.  Therefore, to "add a node" you would need to split the column at the first floor.
Joe
in reply to: Joe.Charpentier
Ok, so to export a structure to Robot. It´s better to have one column per floor?
