Dear all
I have a problem with analytical beam and slab not coincide
please see picture and my file
THANKS ALL
You can do one of two things:
-Change the Auto-detect settings so that the slab edge adjusts to the beam.
-Manually adjust the analytical model using the Analytical adjust tool.
You may need to adjust the Auto-detect tolerance, depending on the offset.
The Slab edge autodetect can be set one of 3 ways:
-per-edge by editing the sketch and setting the properties of the sketch line
-for the entire slab by selecting the analytical model and adjusting the Projection settings in the ribbon
-per-edge by tab-selecting the edge of the analytical model and adjusting the Projection settings in the ribbon
Joe
