I´m a beginner in Revit .From Where do I load these(and others) steel shape families?
I´m using Revit structure 2014.
thx
Rafael Medeiros
Hello Rafacascudo,
When you load families into a project, the Revit family library is accessed by default. The library is located here: %ALLUSERSPROFILE%\Autodesk\<product name and release>\Libraries
If you cannot find the family in the Libraries, please find the family in this site. Autodesk Seek is the online source for product specifications and models for use in Revit.
Hop this helps.
______________________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
OR you can use "extensions->tools->content generator" if you are installed "Revit Extensions for Autodesk Revit". These extensions are available if you have Autodesk Subscription atttached to your license
"extensions->tools->content generator" worked!!
Thx a lot!
AISC shapes showed up nicely , but not the canadian(CISC) ones. Any ideas??
Rafael Medeiros
In content generator window choose from File->Regional_Settings : Canada
