Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
アーチ形状の梁
1 REPLY 1
sunkouzou
635 Views, 1 Reply
アーチ形状の梁
H鋼でアーチ形状の梁をかけたいのですが設置方法、作成方法がわかりません。教えていただけないでしょうか?
1 REPLY 1
AJA14
in reply to: sunkouzou
I think you have a better option if you write your question in English.
Anyways, from the translation, you need to create an arch shaped H beam.
If it is horizontal, you can simply draw it using the arc tool after you start the beam tool. If it's vertical, an easy way is to use the truss tool and modify the profile.
Ali Al-Hammoud
Structural Design Engineer
MZ & Partners Engineering Consultancy
