Anybody used them yet?
I've got a project that we just updated from 2012. I'm trying to replace some of the grid lines with this new "feature." However I'm running into some issues.
Once I place the grid, it seems to lock up. I cannot change the Grid Name, nor can I erase/delete the grid without undoing.
Anybody else have issues?
Leanne, is this a workshared file?
Are the grids being created on a workset that is locked/checked out?
I'm assuming you don't get the same behavior with regular grids.
Joe
Yes. This is on a workshared file. I do not have the issue with regular, one-segment grids. The current workset is Workset1 and I am the only one in the project at the moment.
I tried starting a brand new 2013 project and placed one multi-segment grid and was able to edit the marker. But once I linked this model into the new model, I was no longer able to edit the bubble.
I also copied that new grid (from the new 2013 project) into my original project, and while I could edit it when I first brought it in, once I tried to create a new one, all editing capabilities were lost again (on both the new and the copied grids.)
ETA: Hmmm. I also see (in the newly created 2013 project) where I created the new grid, I can click on it and see "Edit Sketch" on the Modify | Multi-segmented Grid tab. I don't get that in my upgraded from 2012 project after I try to make a new one.
Adding more information to the thread...
I wonder if the issue has anything to do with the fact that I had temporarily hidden a couple other grids in the project.
The project was started in 2012. A grid in this project (ballpark, to give you an idea of the shape) required two straight segments and one arc. When I upgraded the project, I hid the three gridlines to draw my new multi-segmented gridlines. (I tried to use the original grid lines as pick lines for my segments of my multi-segmented grid but kept getting an error about too many loops, or something.)
When I Reset Temporary Hide/Isolate, the grid lines become available for editing again.
