How can I curve a beam, I already know how in plan view. Whait I am trying to do is create a bow beam out of a steel member, I have an idea with a profile and extruding it along a path, any other suggestions?
Draw a grid line in plan (say G1) along which you want to draw the bowed beam, Now in elevation set your work pane to G1 and draw a detail line (in the shape of bow you require) now add a beam and use pickline (select the detail line you had drawn)
Hope it works for you
