Show only
Search instead for
In 2009 with the new dimension text overrides. Can you lock the text so that when you change the witness lines the text doesn’t automatically change back to the Actual Value?
For instance, I make a dimension from something to the inside face of a wall then I "Replace with text". If I edit the Witness Line to the outside face, then the dimension changes back to "Use Actual Value"
