Probably a very easy question but I cant find it.
I would like to draw a strucutal beam of a very standard european profile, e.g. profiles shown below.
HEA
HEB
IPE
Unfortunately when I go to the - Load Family - I cant find these Families/Profiles?
Any suggestion where I can find them (or downlaod?)
Many thanks,
Solved by ralphdenhaan. Go to Solution.
Hi @knippie ,
You can downlaod the libaries from Autodesk if not installed yet. What Revit version do you use? In case of 2024 you can use this link: https://www.autodesk.com/support/technical/article/caas/tsarticles/ts/2BQRb68xV4vUxhiNWfnv7k.html
Search for EURO content and install: https://up1.autodesk.com/2024/RVT/486B91A6-23A6-3540-9B2E-99C45BFE6350/RVTCPENEURO.exe
Select Accept as Solution and Likes are always welcome.
Ralph den Haan, (Lazy) BIM Specialist
Thanks for your quick reply!
It is a bit strange, I cant find the folder 'european specific' (onlu UK and USA). Would it be possible to send the folder path, so I can double check that I am looking in the right place?
At the momemt I am using Revit2023, would it be possible to share the link for these families to download?
Many thanks again! 🙂
You can download the content for Revit 23 here:
English EURO content:
https://up.autodesk.com/2023/RVT/2386881F-E824-3C03-9111-17AF5F3B81A0/RVTCPENEURO.exe
Or NETHERLANDS:
https://up.autodesk.com/2023/RVT/723C5366-2C15-32A2-AC4E-0F2018E5CC82/RVTCPENNETHERLANDS.exe
And this will be your folder location:
C:\ProgramData\Autodesk\RVT 2023\Libraries
