I want to change the units in the layer summary to inches for spacing. All my project units are set to this and it work with other label parameters except this one. Is there any way to change how the layer summary presents?
Solved by okapawal. Go to Solution.
Have you changed Reinforcement Spacing unit in the project?
It seems that it is wrongly associated with Reinforcement Length unit.
And there is another bug, the tag is not refreshed after unit change.
You need to move it to be refreshed.
Sorry, I will report this to be fixed.
Please, how did you tag/annotate your area reba to show number of rebar, bar type and size, with spacing?
Thank you.
@israel.olaosebikan wrote:Hello,
Thank you.
I just modified the out of the box area reinforcement tag which is just using the "layer summary" parameter to gather all the info. They have still not fixed the bug about the spacing though. So if you want the units of the spacing to be inches you have to change the units of the bar length. Hopefully they will fix this.
Nice to see that over a year has gone by and such a simple bug hasn't been addressed.
