Não consigo nem passar da primeira fase da instalação, que é de 12 fases! Não sei como proceder, já fiz de tudo, até tentei o 32bits mas n deu...aparece o seguinte:
2014/8/26:16:44:24 Marcela Ottoboni MARCELAOTTOBONI === Setup started on MARCELAOTTOBONI by Marcela Ottoboni ===
2014/8/26:16:44:24 Marcela Ottoboni MARCELAOTTOBONI Path_Length: 155
2014/8/26:16:44:24 Marcela Ottoboni MARCELAOTTOBONI Current Directory F:\REVIT 2015 PORTUGUES\Autodesk_Revit_2015_Brazilian_Portuguese
2014/8/26:16:44:24 Marcela Ottoboni MARCELAOTTOBONI Launch
2014/8/26:16:44:24 Marcela Ottoboni MARCELAOTTOBONI CommandLine
2014/8/26:16:44:24 Marcela Ottoboni MARCELAOTTOBONI Current Directory C:\Users\MARCEL~1\AppData\Local\Temp\_AI83D1.tmp
2014/8/26:16:44:44 Marcela Ottoboni MARCELAOTTOBONI === Setup ended ===
2014/8/26:16:44:32 Marcela Ottoboni MARCELAOTTOBONI === Setup started on MARCELAOTTOBONI by Marcela Ottoboni ===
2014/8/26:16:44:32 Marcela Ottoboni MARCELAOTTOBONI Path_Length: 155
2014/8/26:16:44:32 Marcela Ottoboni MARCELAOTTOBONI Current Directory C:\Users\MARCEL~1\AppData\Local\Temp\_AI83D1.tmp
2014/8/26:16:44:32 Marcela Ottoboni MARCELAOTTOBONI Launch
2014/8/26:16:44:33 Marcela Ottoboni MARCELAOTTOBONI Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomCallbackRevitOSVersionCheck CB_SOURCE=C:\Users\MARCEL~1\AppData\Local\Temp\_AI83D1.tmp\Setup\RevitSetup.dll
2014/8/26:16:44:34 Marcela Ottoboni MARCELAOTTOBONI Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2014/8/26:16:44:39 Marcela Ottoboni MARCELAOTTOBONI Install CustomCallback Info Invoking custom callback for details: [RCL2015] CB_FUNC=CustomCallbackRevitContentWarning CB_SOURCE=C:\Users\MARCEL~1\AppData\Local\Temp\_AI83D1.tmp\Setup\RevitSetup.dll
2014/8/26:16:44:39 Marcela Ottoboni MARCELAOTTOBONI Install CustomCallback Info Custom callback response: Status=1 INFO Title= Message=O cancelamento da seleção da instalação co conteúdo irá afetar configurações críticas no Autodesk® Revit® 2015. URLTitle= URLLink=
2014/8/26:16:44:44 Marcela Ottoboni MARCELAOTTOBONI PageOpen LaunchDialog
2014/8/26:16:44:49 Marcela Ottoboni MARCELAOTTOBONI PageOpen LicenseDialog
2014/8/26:16:44:53 Marcela Ottoboni MARCELAOTTOBONI PageOpen ProductInfoDialog
2014/8/26:16:49:27 Marcela Ottoboni MARCELAOTTOBONI PageOpen ProductSelectionDialog2
2014/8/26:16:49:55 Marcela Ottoboni MARCELAOTTOBONI PageOpen FullProgressDialog
2014/8/26:16:49:55 Marcela Ottoboni MARCELAOTTOBONI Installing Microsoft Visual C++ 2012 Redistributable (x86): "F:\REVIT 2015 PORTUGUES\Autodesk_Revit_2015_Brazilian_Portuguese\3rdParty\x86\VCRedist\2012\vcredist_x86.exe" /install /quiet /norestart
2014/8/26:16:50:10 Marcela Ottoboni MARCELAOTTOBONI Install Microsoft Visual C++ 2012 Redistributable (x86) Succeeded
2014/8/26:16:50:10 Marcela Ottoboni MARCELAOTTOBONI Installing Microsoft Visual C++ 2012 Redistributable (x64): "F:\REVIT 2015 PORTUGUES\Autodesk_Revit_2015_Brazilian_Portuguese\3rdParty\x64\VCRedist\2012\vcredist_x64.exe" /install /quiet /norestart
2014/8/26:16:50:17 Marcela Ottoboni MARCELAOTTOBONI Install Microsoft Visual C++ 2012 Redistributable (x64) Succeeded
2014/8/26:16:50:32 Marcela Ottoboni MARCELAOTTOBONI Rollback Microsoft Visual C++ 2012 Redistributable (x64) Failed Installation aborted, Result=1619
2014/8/26:16:50:32 Marcela Ottoboni MARCELAOTTOBONI Rollback Microsoft Visual C++ 2012 Redistributable (x86) Failed Installation aborted, Result=1619
2014/8/26:16:50:34 Marcela Ottoboni MARCELAOTTOBONI PageOpen InstallCompleteDialog
2014/8/26:16:50:36 Marcela Ottoboni MARCELAOTTOBONI === Setup ended ===
2014/8/26:16:52:57 Marcela Ottoboni MARCELAOTTOBONI === Setup started on MARCELAOTTOBONI by Marcela Ottoboni ===
2014/8/26:16:52:57 Marcela Ottoboni MARCELAOTTOBONI Path_Length: 155
2014/8/26:16:52:57 Marcela Ottoboni MARCELAOTTOBONI Current Directory F:\REVIT 2015 PORTUGUES\Autodesk_Revit_2015_Brazilian_Portuguese
2014/8/26:16:52:57 Marcela Ottoboni MARCELAOTTOBONI Launch
2014/8/26:16:52:57 Marcela Ottoboni MARCELAOTTOBONI CommandLine
2014/8/26:16:52:57 Marcela Ottoboni MARCELAOTTOBONI Current Directory C:\Users\MARCEL~1\AppData\Local\Temp\_AI57D8.tmp
2014/8/26:16:53:08 Marcela Ottoboni MARCELAOTTOBONI === Setup ended ===
2014/8/26:16:53:01 Marcela Ottoboni MARCELAOTTOBONI === Setup started on MARCELAOTTOBONI by Marcela Ottoboni ===
2014/8/26:16:53:01 Marcela Ottoboni MARCELAOTTOBONI Path_Length: 155
2014/8/26:16:53:01 Marcela Ottoboni MARCELAOTTOBONI Current Directory C:\Users\MARCEL~1\AppData\Local\Temp\_AI57D8.tmp
2014/8/26:16:53:01 Marcela Ottoboni MARCELAOTTOBONI Launch
2014/8/26:16:53:02 Marcela Ottoboni MARCELAOTTOBONI Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomCallbackRevitOSVersionCheck CB_SOURCE=C:\Users\MARCEL~1\AppData\Local\Temp\_AI57D8.tmp\Setup\RevitSetup.dll
2014/8/26:16:53:02 Marcela Ottoboni MARCELAOTTOBONI Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2014/8/26:16:53:06 Marcela Ottoboni MARCELAOTTOBONI Install CustomCallback Info Invoking custom callback for details: [RCL2015] CB_FUNC=CustomCallbackRevitContentWarning CB_SOURCE=C:\Users\MARCEL~1\AppData\Local\Temp\_AI57D8.tmp\Setup\RevitSetup.dll
2014/8/26:16:53:06 Marcela Ottoboni MARCELAOTTOBONI Install CustomCallback Info Custom callback response: Status=1 INFO Title= Message=O cancelamento da seleção da instalação co conteúdo irá afetar configurações críticas no Autodesk® Revit® 2015. URLTitle= URLLink=
2014/8/26:16:53:07 Marcela Ottoboni MARCELAOTTOBONI PageOpen LaunchDialog
2014/8/26:16:53:13 Marcela Ottoboni MARCELAOTTOBONI PageOpen LicenseDialog
2014/8/26:16:53:16 Marcela Ottoboni MARCELAOTTOBONI PageOpen ProductInfoDialog
2014/8/26:16:53:31 Marcela Ottoboni MARCELAOTTOBONI PageOpen ProductSelectionDialog2
2014/8/26:16:53:34 Marcela Ottoboni MARCELAOTTOBONI PageOpen FullProgressDialog
2014/8/26:16:53:35 Marcela Ottoboni MARCELAOTTOBONI Installing Microsoft Visual C++ 2012 Redistributable (x86): "F:\REVIT 2015 PORTUGUES\Autodesk_Revit_2015_Brazilian_Portuguese\3rdParty\x86\VCRedist\2012\vcredist_x86.exe" /install /quiet /norestart
2014/8/26:16:53:35 Marcela Ottoboni MARCELAOTTOBONI Install Microsoft Visual C++ 2012 Redistributable (x86) Failed Installation aborted, Result=-2147024546
2014/8/26:16:53:36 Marcela Ottoboni MARCELAOTTOBONI PageOpen InstallCompleteDialog
2014/8/26:16:53:56 Marcela Ottoboni MARCELAOTTOBONI === Setup ended ===
2014/8/26:16:54:07 Marcela Ottoboni MARCELAOTTOBONI === Setup started on MARCELAOTTOBONI by Marcela Ottoboni ===
2014/8/26:16:54:07 Marcela Ottoboni MARCELAOTTOBONI Path_Length: 155
2014/8/26:16:54:07 Marcela Ottoboni MARCELAOTTOBONI Current Directory F:\REVIT 2015 PORTUGUES\Autodesk_Revit_2015_Brazilian_Portuguese
2014/8/26:16:54:07 Marcela Ottoboni MARCELAOTTOBONI Launch
2014/8/26:16:54:07 Marcela Ottoboni MARCELAOTTOBONI CommandLine
2014/8/26:16:54:07 Marcela Ottoboni MARCELAOTTOBONI Current Directory C:\Users\MARCEL~1\AppData\Local\Temp\_AI6929.tmp
2014/8/26:16:54:15 Marcela Ottoboni MARCELAOTTOBONI === Setup ended ===
2014/8/26:16:54:09 Marcela Ottoboni MARCELAOTTOBONI === Setup started on MARCELAOTTOBONI by Marcela Ottoboni ===
2014/8/26:16:54:09 Marcela Ottoboni MARCELAOTTOBONI Path_Length: 155
2014/8/26:16:54:09 Marcela Ottoboni MARCELAOTTOBONI Current Directory C:\Users\MARCEL~1\AppData\Local\Temp\_AI6929.tmp
2014/8/26:16:54:09 Marcela Ottoboni MARCELAOTTOBONI Launch
2014/8/26:16:54:10 Marcela Ottoboni MARCELAOTTOBONI Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomCallbackRevitOSVersionCheck CB_SOURCE=C:\Users\MARCEL~1\AppData\Local\Temp\_AI6929.tmp\Setup\RevitSetup.dll
2014/8/26:16:54:10 Marcela Ottoboni MARCELAOTTOBONI Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2014/8/26:16:54:14 Marcela Ottoboni MARCELAOTTOBONI Install CustomCallback Info Invoking custom callback for details: [RCL2015] CB_FUNC=CustomCallbackRevitContentWarning CB_SOURCE=C:\Users\MARCEL~1\AppData\Local\Temp\_AI6929.tmp\Setup\RevitSetup.dll
2014/8/26:16:54:14 Marcela Ottoboni MARCELAOTTOBONI Install CustomCallback Info Custom callback response: Status=1 INFO Title= Message=O cancelamento da seleção da instalação co conteúdo irá afetar configurações críticas no Autodesk® Revit® 2015. URLTitle= URLLink=
2014/8/26:16:54:15 Marcela Ottoboni MARCELAOTTOBONI PageOpen LaunchDialog
2014/8/26:16:54:16 Marcela Ottoboni MARCELAOTTOBONI PageOpen LicenseDialog
2014/8/26:16:54:18 Marcela Ottoboni MARCELAOTTOBONI PageOpen ProductInfoDialog
2014/8/26:16:54:32 Marcela Ottoboni MARCELAOTTOBONI PageOpen ProductSelectionDialog2
2014/8/26:16:54:36 Marcela Ottoboni MARCELAOTTOBONI PageOpen FullProgressDialog
2014/8/26:16:54:37 Marcela Ottoboni MARCELAOTTOBONI Installing Microsoft Visual C++ 2012 Redistributable (x86): "F:\REVIT 2015 PORTUGUES\Autodesk_Revit_2015_Brazilian_Portuguese\3rdParty\x86\VCRedist\2012\vcredist_x86.exe" /install /quiet /norestart
2014/8/26:16:54:37 Marcela Ottoboni MARCELAOTTOBONI Install Microsoft Visual C++ 2012 Redistributable (x86) Failed Installation aborted, Result=-2147024546
2014/8/26:16:54:38 Marcela Ottoboni MARCELAOTTOBONI PageOpen InstallCompleteDialog
2014/8/26:16:54:45 Marcela Ottoboni MARCELAOTTOBONI === Setup ended ===
2014/8/26:16:57:12 Marcela Ottoboni MARCELAOTTOBONI === Setup started on MARCELAOTTOBONI by Marcela Ottoboni ===
2014/8/26:16:57:12 Marcela Ottoboni MARCELAOTTOBONI Path_Length: 155
2014/8/26:16:57:12 Marcela Ottoboni MARCELAOTTOBONI Current Directory F:\REVIT 2015 PORTUGUES\Autodesk_Revit_2015_Brazilian_Portuguese
2014/8/26:16:57:12 Marcela Ottoboni MARCELAOTTOBONI Launch
2014/8/26:16:57:12 Marcela Ottoboni MARCELAOTTOBONI CommandLine
2014/8/26:16:57:12 Marcela Ottoboni MARCELAOTTOBONI Current Directory C:\Users\MARCEL~1\AppData\Local\Temp\_AI3C6D.tmp
2014/8/26:16:57:19 Marcela Ottoboni MARCELAOTTOBONI === Setup ended ===
2014/8/26:16:57:14 Marcela Ottoboni MARCELAOTTOBONI === Setup started on MARCELAOTTOBONI by Marcela Ottoboni ===
2014/8/26:16:57:14 Marcela Ottoboni MARCELAOTTOBONI Path_Length: 155
2014/8/26:16:57:14 Marcela Ottoboni MARCELAOTTOBONI Current Directory C:\Users\MARCEL~1\AppData\Local\Temp\_AI3C6D.tmp
2014/8/26:16:57:14 Marcela Ottoboni MARCELAOTTOBONI Launch
2014/8/26:16:57:15 Marcela Ottoboni MARCELAOTTOBONI Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomCallbackRevitOSVersionCheck CB_SOURCE=C:\Users\MARCEL~1\AppData\Local\Temp\_AI3C6D.tmp\Setup\RevitSetup.dll
2014/8/26:16:57:15 Marcela Ottoboni MARCELAOTTOBONI Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2014/8/26:16:57:18 Marcela Ottoboni MARCELAOTTOBONI Install CustomCallback Info Invoking custom callback for details: [RCL2015] CB_FUNC=CustomCallbackRevitContentWarning CB_SOURCE=C:\Users\MARCEL~1\AppData\Local\Temp\_AI3C6D.tmp\Setup\RevitSetup.dll
2014/8/26:16:57:18 Marcela Ottoboni MARCELAOTTOBONI Install CustomCallback Info Custom callback response: Status=1 INFO Title= Message=O cancelamento da seleção da instalação co conteúdo irá afetar configurações críticas no Autodesk® Revit® 2015. URLTitle= URLLink=
2014/8/26:16:57:19 Marcela Ottoboni MARCELAOTTOBONI PageOpen LaunchDialog
2014/8/26:16:57:21 Marcela Ottoboni MARCELAOTTOBONI PageOpen LicenseDialog
2014/8/26:16:57:23 Marcela Ottoboni MARCELAOTTOBONI PageOpen ProductInfoDialog
2014/8/26:16:57:45 Marcela Ottoboni MARCELAOTTOBONI PageOpen ProductSelectionDialog2
2014/8/26:16:57:49 Marcela Ottoboni MARCELAOTTOBONI PageOpen FullProgressDialog
2014/8/26:16:57:50 Marcela Ottoboni MARCELAOTTOBONI Installing Microsoft Visual C++ 2012 Redistributable (x86): "F:\REVIT 2015 PORTUGUES\Autodesk_Revit_2015_Brazilian_Portuguese\3rdParty\x86\VCRedist\2012\vcredist_x86.exe" /install /quiet /norestart
2014/8/26:16:57:50 Marcela Ottoboni MARCELAOTTOBONI Install Microsoft Visual C++ 2012 Redistributable (x86) Failed Installation aborted, Result=-2147024546
2014/8/26:16:57:51 Marcela Ottoboni MARCELAOTTOBONI PageOpen InstallCompleteDialog
2014/8/26:16:58:03 Marcela Ottoboni MARCELAOTTOBONI === Setup ended ===
2014/8/26:17:02:02 Marcela Ottoboni MARCELAOTTOBONI === Setup started on MARCELAOTTOBONI by Marcela Ottoboni ===
2014/8/26:17:02:02 Marcela Ottoboni MARCELAOTTOBONI Path_Length: 155
2014/8/26:17:02:02 Marcela Ottoboni MARCELAOTTOBONI Current Directory F:\REVIT 2015 PORTUGUES\Autodesk_Revit_2015_Brazilian_Portuguese
2014/8/26:17:02:02 Marcela Ottoboni MARCELAOTTOBONI Launch
2014/8/26:17:02:02 Marcela Ottoboni MARCELAOTTOBONI CommandLine
2014/8/26:17:02:02 Marcela Ottoboni MARCELAOTTOBONI Current Directory C:\Users\MARCEL~1\AppData\Local\Temp\_AIA872.tmp
2014/8/26:17:02:20 Marcela Ottoboni MARCELAOTTOBONI === Setup ended ===
2014/8/26:17:02:10 Marcela Ottoboni MARCELAOTTOBONI === Setup started on MARCELAOTTOBONI by Marcela Ottoboni ===
2014/8/26:17:02:10 Marcela Ottoboni MARCELAOTTOBONI Path_Length: 155
2014/8/26:17:02:10 Marcela Ottoboni MARCELAOTTOBONI Current Directory C:\Users\MARCEL~1\AppData\Local\Temp\_AIA872.tmp
2014/8/26:17:02:10 Marcela Ottoboni MARCELAOTTOBONI Launch
2014/8/26:17:02:10 Marcela Ottoboni MARCELAOTTOBONI Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomCallbackRevitOSVersionCheck CB_SOURCE=C:\Users\MARCEL~1\AppData\Local\Temp\_AIA872.tmp\Setup\RevitSetup.dll
2014/8/26:17:02:10 Marcela Ottoboni MARCELAOTTOBONI Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2014/8/26:17:02:15 Marcela Ottoboni MARCELAOTTOBONI Install CustomCallback Info Invoking custom callback for details: [RCL2015] CB_FUNC=CustomCallbackRevitContentWarning CB_SOURCE=C:\Users\MARCEL~1\AppData\Local\Temp\_AIA872.tmp\Setup\RevitSetup.dll
2014/8/26:17:02:15 Marcela Ottoboni MARCELAOTTOBONI Install CustomCallback Info Custom callback response: Status=1 INFO Title= Message=O cancelamento da seleção da instalação co conteúdo irá afetar configurações críticas no Autodesk® Revit® 2015. URLTitle= URLLink=
2014/8/26:17:02:19 Marcela Ottoboni MARCELAOTTOBONI PageOpen LaunchDialog
2014/8/26:17:02:27 Marcela Ottoboni MARCELAOTTOBONI PageOpen LicenseDialog
2014/8/26:17:02:30 Marcela Ottoboni MARCELAOTTOBONI PageOpen ProductInfoDialog
2014/8/26:17:02:47 Marcela Ottoboni MARCELAOTTOBONI PageOpen ProductSelectionDialog2
2014/8/26:17:02:49 Marcela Ottoboni MARCELAOTTOBONI PageOpen FullProgressDialog
2014/8/26:17:02:50 Marcela Ottoboni MARCELAOTTOBONI Installing Microsoft Visual C++ 2012 Redistributable (x86): "F:\REVIT 2015 PORTUGUES\Autodesk_Revit_2015_Brazilian_Portuguese\3rdParty\x86\VCRedist\2012\vcredist_x86.exe" /install /quiet /norestart
2014/8/26:17:02:50 Marcela Ottoboni MARCELAOTTOBONI Install Microsoft Visual C++ 2012 Redistributable (x86) Failed Installation aborted, Result=-2147024546
2014/8/26:17:02:52 Marcela Ottoboni MARCELAOTTOBONI PageOpen InstallCompleteDialog
2014/8/26:17:02:56 Marcela Ottoboni MARCELAOTTOBONI === Setup ended ===
2014/8/26:21:03:32 Marcela Ottoboni MARCELAOTTOBONI === Setup started on MARCELAOTTOBONI by Marcela Ottoboni ===
2014/8/26:21:03:32 Marcela Ottoboni MARCELAOTTOBONI Path_Length: 155
2014/8/26:21:03:32 Marcela Ottoboni MARCELAOTTOBONI Current Directory C:\Autodesk\Autodesk_Revit_2015_Brazilian_Portuguese_Win_64bit_R2_wi_pt-BR
2014/8/26:21:03:32 Marcela Ottoboni MARCELAOTTOBONI Launch
2014/8/26:21:03:32 Marcela Ottoboni MARCELAOTTOBONI CommandLine /url "http://trial2.autodesk.com/SWDLDNET4/2015/RVT/WI/Autodesk_Revit_2015_Brazilian_Portuguese_Win_64bit_... /SN 900-27153935 /PK 829G1 /student /akamai /skipEULA /auth authparam /sid SESSION_ID
2014/8/26:21:03:32 Marcela Ottoboni MARCELAOTTOBONI Current Directory C:\Users\MARCEL~1\AppData\Local\Temp\_AIC02D.tmp
2014/8/26:21:04:22 Marcela Ottoboni MARCELAOTTOBONI === Setup ended ===
2014/8/26:21:03:35 Marcela Ottoboni MARCELAOTTOBONI === Setup started on MARCELAOTTOBONI by Marcela Ottoboni ===
2014/8/26:21:03:35 Marcela Ottoboni MARCELAOTTOBONI Path_Length: 155
2014/8/26:21:03:35 Marcela Ottoboni MARCELAOTTOBONI Current Directory C:\Users\MARCEL~1\AppData\Local\Temp\_AIC02D.tmp
2014/8/26:21:03:35 Marcela Ottoboni MARCELAOTTOBONI Launch
2014/8/26:21:03:37 Marcela Ottoboni MARCELAOTTOBONI Download Play SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET4/2015/RVT/WI/{4726CF80-4F4A-4EE2-98AC-36A96E20DB56}/SETUP_x64.ta...
2014/8/26:21:04:20 Marcela Ottoboni MARCELAOTTOBONI Download Complete SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET4/2015/RVT/WI/{4726CF80-4F4A-4EE2-98AC-36A96E20DB56}/SETUP_x64.ta...
2014/8/26:21:04:20 Marcela Ottoboni MARCELAOTTOBONI Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomCallbackRevitOSVersionCheck CB_SOURCE=C:\Users\MARCEL~1\AppData\Local\Temp\_AIC02D.tmp\Setup\RevitSetup.dll
2014/8/26:21:04:21 Marcela Ottoboni MARCELAOTTOBONI Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2014/8/26:21:04:22 Marcela Ottoboni MARCELAOTTOBONI PageOpen LaunchDialog
2014/8/26:21:04:29 Marcela Ottoboni MARCELAOTTOBONI Install CustomCallback Info Invoking custom callback for details: [RCL2015] CB_FUNC=CustomCallbackRevitContentWarning CB_SOURCE=C:\Users\MARCEL~1\AppData\Local\Temp\_AIC02D.tmp\Setup\RevitSetup.dll
2014/8/26:21:04:29 Marcela Ottoboni MARCELAOTTOBONI Install CustomCallback Info Custom callback response: Status=1 INFO Title= Message=O cancelamento da seleção da instalação co conteúdo irá afetar configurações críticas no Autodesk® Revit® 2015. URLTitle= URLLink=
2014/8/26:21:07:40 Marcela Ottoboni MARCELAOTTOBONI PageOpen LicenseDialog
2014/8/26:21:07:40 Marcela Ottoboni MARCELAOTTOBONI PageOpen ProductInfoDialog
2014/8/26:21:07:40 Marcela Ottoboni MARCELAOTTOBONI PageOpen ProductSelectionDialog2
2014/8/26:21:08:14 Marcela Ottoboni MARCELAOTTOBONI PageOpen FullProgressDialog
2014/8/26:21:08:18 Marcela Ottoboni MARCELAOTTOBONI Download Play VCREDIST2012X86 http://trial2.autodesk.com/SWDLDNET4/2015/RVT/WI/{4726CF80-4F4A-4EE2-98AC-36A96E20DB56}/VCREDIST2012...
2014/8/26:21:08:55 Marcela Ottoboni MARCELAOTTOBONI Download Complete VCREDIST2012X86 http://trial2.autodesk.com/SWDLDNET4/2015/RVT/WI/{4726CF80-4F4A-4EE2-98AC-36A96E20DB56}/VCREDIST2012...
2014/8/26:21:08:55 Marcela Ottoboni MARCELAOTTOBONI Installing Microsoft Visual C++ 2012 Redistributable (x86): "C:\Autodesk\WI\Autodesk Revit 2015\3rdParty\x86\VCRedist\2012\vcredist_x86.exe" /install /quiet /norestart
2014/8/26:21:08:56 Marcela Ottoboni MARCELAOTTOBONI Install Microsoft Visual C++ 2012 Redistributable (x86) Failed Installation aborted, Result=-2147024546
2014/8/26:21:08:57 Marcela Ottoboni MARCELAOTTOBONI PageOpen InstallCompleteDialog
2014/8/26:21:09:22 Marcela Ottoboni MARCELAOTTOBONI === Setup ended ===
2014/8/26:21:19:22 Marcela Ottoboni MARCELAOTTOBONI === Setup started on MARCELAOTTOBONI by Marcela Ottoboni ===
2014/8/26:21:19:22 Marcela Ottoboni MARCELAOTTOBONI Path_Length: 155
2014/8/26:21:19:22 Marcela Ottoboni MARCELAOTTOBONI Current Directory C:\Autodesk\Autodesk_Revit_2015_Brazilian_Portuguese_Win_64bit_R2_wi_pt-BR
2014/8/26:21:19:22 Marcela Ottoboni MARCELAOTTOBONI Launch
2014/8/26:21:19:22 Marcela Ottoboni MARCELAOTTOBONI CommandLine /url "http://trial2.autodesk.com/SWDLDNET4/2015/RVT/WI/Autodesk_Revit_2015_Brazilian_Portuguese_Win_64bit_... /SN 900-27153935 /PK 829G1 /student /akamai /skipEULA /auth authparam /sid SESSION_ID
2014/8/26:21:19:22 Marcela Ottoboni MARCELAOTTOBONI Current Directory C:\Users\MARCEL~1\AppData\Local\Temp\_AI3BC2.tmp
2014/8/26:21:19:27 Marcela Ottoboni MARCELAOTTOBONI === Setup ended ===
2014/8/26:21:19:24 Marcela Ottoboni MARCELAOTTOBONI === Setup started on MARCELAOTTOBONI by Marcela Ottoboni ===
2014/8/26:21:19:24 Marcela Ottoboni MARCELAOTTOBONI Path_Length: 155
2014/8/26:21:19:24 Marcela Ottoboni MARCELAOTTOBONI Current Directory C:\Users\MARCEL~1\AppData\Local\Temp\_AI3BC2.tmp
2014/8/26:21:19:24 Marcela Ottoboni MARCELAOTTOBONI Launch
2014/8/26:21:19:25 Marcela Ottoboni MARCELAOTTOBONI Download Skipped SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET4/2015/RVT/WI/{4726CF80-4F4A-4EE2-98AC-36A96E20DB56}/SETUP_x64.ta...
2014/8/26:21:19:25 Marcela Ottoboni MARCELAOTTOBONI Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomCallbackRevitOSVersionCheck CB_SOURCE=C:\Users\MARCEL~1\AppData\Local\Temp\_AI3BC2.tmp\Setup\RevitSetup.dll
2014/8/26:21:19:25 Marcela Ottoboni MARCELAOTTOBONI Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2014/8/26:21:19:27 Marcela Ottoboni MARCELAOTTOBONI PageOpen LaunchDialog
2014/8/26:21:19:35 Marcela Ottoboni MARCELAOTTOBONI Install CustomCallback Info Invoking custom callback for details: [RCL2015] CB_FUNC=CustomCallbackRevitContentWarning CB_SOURCE=C:\Users\MARCEL~1\AppData\Local\Temp\_AI3BC2.tmp\Setup\RevitSetup.dll
2014/8/26:21:19:35 Marcela Ottoboni MARCELAOTTOBONI Install CustomCallback Info Custom callback response: Status=1 INFO Title= Message=O cancelamento da seleção da instalação co conteúdo irá afetar configurações críticas no Autodesk® Revit® 2015. URLTitle= URLLink=
2014/8/26:21:20:13 Marcela Ottoboni MARCELAOTTOBONI PageOpen LicenseDialog
2014/8/26:21:20:13 Marcela Ottoboni MARCELAOTTOBONI PageOpen ProductInfoDialog
2014/8/26:21:20:13 Marcela Ottoboni MARCELAOTTOBONI PageOpen ProductSelectionDialog2
2014/8/26:21:20:24 Marcela Ottoboni MARCELAOTTOBONI PageOpen FullProgressDialog
2014/8/26:21:20:24 Marcela Ottoboni MARCELAOTTOBONI Download Skipped VCREDIST2012X86 http://trial2.autodesk.com/SWDLDNET4/2015/RVT/WI/{4726CF80-4F4A-4EE2-98AC-36A96E20DB56}/VCREDIST2012...
2014/8/26:21:20:24 Marcela Ottoboni MARCELAOTTOBONI Installing Microsoft Visual C++ 2012 Redistributable (x86): "C:\Autodesk\WI\Autodesk Revit 2015\3rdParty\x86\VCRedist\2012\vcredist_x86.exe" /install /quiet /norestart
2014/8/26:21:20:25 Marcela Ottoboni MARCELAOTTOBONI Install Microsoft Visual C++ 2012 Redistributable (x86) Failed Installation aborted, Result=-2147024546
Tente baixar e instalar separadamente o Microsoft Visual C++ 2012 Redistributable (x86) (http://www.microsoft.com/en-us/download/details.aspx?id=30679)
Outra solução:
Abra a pasta Disco Local C, clique com o botão direito do mouse na pasta Autodesk (local na qual eu extrai a instalação do Revit e Autocad) e clique em Propriedades, depois que abrir a janela clique na guia Segurança, no campo Nomes de grupo ou usuários clique no usuário Administradores, no campo Permissões para usuários autenticados as permissões possívelmente estarão todas desativadas, ative tudo e depois clique em Aplicar e Ok, depois execute o arquivo setup da instalação do Revit como administrador
OBS: Resposta retirada de outro tópicpo do forum!
Não encontrou o que está procurando? Pergunte à comunidade ou compartilhe seu conhecimento.
