Revit MEP Forum
xref wanderer
2 REPLIES 2
revitworkbench
283 Views, 2 Replies
xref wanderer
Hi, I am trying to import a CAD file that seems to be almost entirely in xrefs. After pulling my hair out, I seem to have gotten the mechanical stuff to come in, but the Architectural stuff is not coming in. Ive set the Layers/Levels button to alll on import, and Ive even tried going into the CAD file and setting the Xref to Attached instead of overlay. But allas the xref remains elusive as ever...Ive tried to Link the CAD file, but that is even worse, only the markups come in then. Anyone have a successful way of tackling elusive xrefs and dropping them into revit? Thanks!
2 REPLIES 2
CoreyDaun
in reply to: revitworkbench
Is the architectural Xref 2D or 3D? Also, if the Arch Xref is nested within another Xref, what Layer is it on?
⁞|⁞ Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate to further enhance these forums. Thank you!
abulla
Can you just bind all of the xrefs in AutoCAD?
