When I want to calculate with °C units, MEP gives me wrong results.
For example:
1°C * 1 = 1 ... OK
1°C * 2 = 275.15 °C ... ?
1°C * 3 = 549.3 °C ... ?
1°C * 4 = 823.45 °C ... ?
Does anyone have a similar problem?
Thank you.
Solved by julianjameson8403. Go to Solution.
Looks like a bug.
The initial temperature given when setting up the parameter appears to be the Celsius equivalent of 1 degree Kelvin? Probably an error in Revits hard coded conversion formula.
Autodesk needs to investigate this by the looks of it.
