Revit MEP Forum
Welcome to Autodesk’s Revit MEP Forums. Share your knowledge, ask questions, and explore popular Revit MEP topics.
Wire Home Runs / Wires
4 REPLIES 4
alijax1972
3408 Views, 4 Replies
How does REVIT 2014 decide whether to show / or not show a home run arrow.
Is there a workflow that I am not adhering to as I replicated the same result in various ways.
Thanks for your responses.
4 REPLIES 4
CoreyDaun
in reply to: alijax1972
It's hard to say from an image. Can you walk through the process you followed in order to create those Wires?
Corey D.        ADSK_Logo_EE_2013.png    AutoCAD 2014 User  Revit 2014 User
⁞|⁞ Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate to further enhance these forums. Thank you!
alijax1972
in reply to: CoreyDaun
1. placed the fittings & switches
2. selected the Switch
3. made it a circuit
4. 'wired' from the switch to the fittings
CoreyDaun
OK, so the Light Fixture are not actually part of the Electrical Circuit; just connecting them with Wire does not associate the elements. When you are drawing the Wire from the Switch, the other end is not being connected to an element on the same Electrical Circuit, hence the creation of the Homerun. In order to add the Light Fixtures to the same Electrical Circuit as the Switch, select the Switch and on the 'Electrical Circuits' tab of the Ribbon, click "Edit Circuit", and then just select the elements that you wish to add to this Electrical Circuit ("Add to Circuit" mode is active by default). See the link below for more information on creating Electrical Circuits.
Revit Help: Creating Power and Lighting Circuits  |  Revit Help: Adding Components to a Circuit
alijax1972
Thanks Corey, it seems when the Light fittings were created they were given a voltage of 0 (zero) & this wasnt picked up, but your workflow is good.
