Revit MEP
Active Contributor
rvetrano
Message 1 of 5 (361 Views)
wire display
361 Views, 4 Replies
05-12-2012 08:57 AM
Hi
I want wire to display as shown in attachment, or simular. I'm trying to create a schematic drawing.
Bob V
parveen.revit
Message 2 of 5 (342 Views)
Re: wire display
05-13-2012 09:30 PM in reply to: rvetrano
you can create this very easily in Revit...
What is your question...
Parveen_Intec_Infocom (BIM, CAD, GIS, QS Services' Provider)
Active Contributor
rvetrano
Message 3 of 5 (337 Views)
Re: wire display
05-14-2012 04:48 AM in reply to: rvetrano
In MEP 2009 you could create wire display automatically. You would select the curiut then select the Create Display button.  I can't find a selection anywhere. In MEP 2011 from what I understand you now have to do it manually. Is this correct?
CADastrophe
Message 4 of 5 (336 Views)
Re: wire display
05-14-2012 05:10 AM in reply to: rvetrano
There are two ways to create permanent wiring when you have the circuit selected as you describe:
1. There are two buttons in the Ribbon under the section "Convert to Wire", which is under the "Modify | Electrical Circuits" contextual tab.
 Note: This is an image of the Revit MEP 2012 ribbon, but the Convert to Wire buttons are the same in Revit MEP 2011.
2. There are two small icons that appear as per the image below; one creates chamfered wire and the other creates arc wire.
It is a relatively common problem for the wire tick marks to be missing as well. If this is the case, just reply back...
Active Contributor
rvetrano
Message 5 of 5 (330 Views)
Re: wire display
05-14-2012 06:40 AM in reply to: CADastrophe
Thanks.
I had tried that once and it didn't work. My project must have been corrutpedor I was doing something wrong. It worked this time.
Again  thank you
Bob v
