Revit MEP
Revit MEP
Active Member
comtois.william
Message 1 of 13 (708 Views)
Which family template should I use to create supports or hangers for pipes?
708 Views, 12 Replies
09-24-2012 07:19 AM
Hi everyone,
I'm new with Revit and I need to create a family of supports or hangers.
Which template should I use if I want to place my supports on my pipes and then adjust the parameters to make it fit on steel beams?
I tried to use Plumbing Fixtures, but when I inserted it in my project, i couldn't place them the way I wanted.
William Comtois
P.S. : I found a topic on the subject, but it didn't really help me out - http://forums.autodesk.com/t5/Autodesk-Revit-MEP/Query-for-pipe-supports-or-hangers-in-Revit-Mep/m-p...
Active Contributor
tjbeecher
Message 2 of 13 (701 Views)
Re: Which family template should I use to create supports or hangers for pipes?
09-24-2012 08:03 AM in reply to: comtois.william
We have used pipe accessories and that seem to work well.
Active Member
comtois.william
Message 3 of 13 (696 Views)
09-24-2012 08:16 AM in reply to: tjbeecher
Am I supose to find this .RFT in the basic templates of Revit MEP?
Otherwise, can you send it to me please? :smileyhappy:
William Comtois
Active Contributor
tjbeecher
Message 4 of 13 (694 Views)
09-24-2012 08:18 AM in reply to: comtois.william
I am using 2013.  I had to create it with a generic model template then change it before I started modeling the hangers.
Active Member
comtois.william
Message 5 of 13 (689 Views)
09-24-2012 08:35 AM in reply to: tjbeecher
Ok, I am using 2013 too, but when you say that you had to change it before you started modeling the hangers, what did you change?
Active Contributor
tjbeecher
Message 6 of 13 (686 Views)
09-24-2012 08:38 AM in reply to: comtois.william
Attached are to pictures. one is showing the family categories and paramteres buttonto click on.  Once the box comes up scroll down to the pipe accessoeris one.
Active Member
comtois.william
Message 7 of 13 (680 Views)
09-24-2012 08:59 AM in reply to: tjbeecher
Well, and do I need to change any parameters or just change the categorie to "pipe accessories"?
I tried to just change the categorie, i modeled something simple (A cylinder) and I tried to insert it in my project. Nothing happened... My cylinder seems not to be added in my project...
Some ideas?
William Comtois
Active Contributor
CADArmor
Message 8 of 13 (598 Views)
10-02-2012 11:49 PM in reply to: comtois.william
Hi you need to be using a Generic Model Template found in (C:\ProgramData\Autodesk\RME 2011\Metric Templates)
Make sure to add Pipe Connectors one in and one out. (See image attached)
For family Category & Parameters make you’re to Part Type is set at Breaks Into (See image attached)
Active Member
comtois.william
Message 9 of 13 (565 Views)
10-04-2012 10:50 AM in reply to: CADArmor
Thanks for your answer,
I tried to create a simple cylinder and to put it down on my piping system the way you told me to do it, but when i do so, some transitions appear on both sides of my cylinder (see image attached)
Is there anything to do to avoid those transitions?
Will
Active Contributor
CADArmor
Message 10 of 13 (533 Views)
10-04-2012 05:55 PM in reply to: comtois.william
Hi mate
You need to make sure that your radius on your pipe connector is the same size as the pipe in your model. See image attached.
