Revit MEP Forum
Welcome to Autodesk’s Revit MEP Forums. Share your knowledge, ask questions, and explore popular Revit MEP topics.
Vertical pipes and ducts show up green
16 REPLIES 16
Message 1 of 17
marco.defina
1236 Views, 16 Replies
i work the last year everytime with Autocad MEP. I Started in this day with Revit Mep why i need to work on a Revit Architectural file.
I have a problem, i can't route ducts in vertical. For example, i route the distribution with all air outlets on the first level, then i need to connect the second level with vertical duct. When i change in the side view i can't to go with duct in vertical (It is impossible to draw on the plan view seen from to acute angle. Move the view or define the work plan).I change the work plan but when i continue the duct i have the same problem, the duct take everytime wrong plan. Why?
BIM Manager - HVAC and Plumbing designer https://www.autodesk.it/content/dam/autodesk/www/products/responsive-imagery/responsive-badges-compare/2019/navisworks-manage-2019-badge-75x75.pngApp AutoCAD per dispositivi mobili premiumNavisWorks Simulate3ds Max___________________________________________________________________________
Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate to further enhance these forums.
16 REPLIES 16
Message 2 of 17
CoreyDaun
in reply to: marco.defina
The subject line of this thread indicates to me that you are seeing the Rise/Drop symbols of the Duct/Pipe. Under Visibility/Graphics Overrides, turn off the Subcategories "Drop" and "Rise" under the "Pipe" and "Duct" Categories. (See image below). If this is not the issue you are having, please post some images to help explain your troubles.
Corey D.        ADSK_Logo_EE_2013.png    AutoCAD 2014 User  Revit 2014 User
⁞|⁞ Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate to further enhance these forums. Thank you!
Message 3 of 17
marco.defina
in reply to: CoreyDaun
I tried but don't work.
I have this situation and i will a duct in vertical in the direction of the red arrow.
I select the side view but i can't go in vertical with ducts.
Message 4 of 17
CoreyDaun
In a Plan View, are you able to draw a Duct to create a 90° using that Duct Type, with an Elbow automatically being placed?
Message 5 of 17
marco.defina
Yes in plan view work all automatically.
Message 6 of 17
CoreyDaun
Try creating the vertical Duct in a perpendicular Elevation/Section View; looking at it from the side rather than straight on as shown in your bottom image. If it still gives you trouble, are you getting an error message if you click to draw the vertical Duct?
Message 7 of 17
marco.defina
Yes i receive error.
This:
It is impossible to draw on the plan view seen from to acute angle. Move the view or define the work plan.
Message 8 of 17
CoreyDaun
Could you post your Project file so I can take a look? What version of Revit are you using?
Message 9 of 17
In the Plan view, click at the starting point of the duct, then change the offset to desired value or level, then click anywhere
if this does not clear your problem go to this link
http://docs.autodesk.com/RVTMPJ/2010/ENU/Revit%20MEP%202010%20Users%20Guide/RME/index.html?url=WS1a9...
Message 10 of 17
marco.defina
REVIT MEP 2014
Attached Project at the link.
 http://ge.tt/9pyURec1
In every project won't work...
Message 11 of 17
Try drawing the elbow in plan view, then click the flip arrow so the elbow is going the correct way you want & see if that works. If it does work you may or may not be able to add duct to it but at least start with this. Also you could try in plan view to change elevation, in other words draw duct say at 10'-0", click on screen then change elevation to say 14'-0" & click again. This should give you an elbow at top & bottom.
Message 12 of 17
marco.defina
with the "trick" to change elevation it works. But it's not possible to use everytime this escamotage.
Can anyone upload a little example project where is possible to modell in vertical the ducts?
Message 13 of 17
bvm76
i tried the drawing you uploaded and i get it worked.
if you want to create a riser hit the "apply" button twice after you put the desired offset; but if you want to create a riser followed by a duct/pipe, hit the "apply" once then click to desired orientation/position of the duct/pipe.
if nothing happens when you follow the steps above, try increasing the elevation difference.
hope this helps.
Please mark Accept as Solution if your question is answered!
Thank You.
Message 14 of 17
marco.defina
in reply to: bvm76
I can't never modell in the sideview...This is the problem.
Here the sequence of commands:
Message 15 of 17
either u can the offset in Plan view or you can draw vertical duct in elevation view.
Message 16 of 17
marco.defina
In elevation view don't work. I can make vertical ducts only with the trick offset change.
Message 17 of 17
marco.defina
OK, i found the solution...I need to change the view not with viewcube but with this and so it works:
red arrow..
Thanks to everybody.
