Does anyone else have a problem with vertical justification? If I justify 2" high cable tray for example to a 9' offset it shows 8' 11" for the bottom and 9' 1" for the top. This is the same no matter if I choose top, center or bottom.
Which version are you using? In 2015 is OK. You can use justification on plan views and you must use the Justification tool in the ribbon, not on the properties window.
Fábio Sato
