Revit MEP Forum
VAV box offset
1 REPLY 1
mars3
450 Views, 1 Reply
VAV box offset
Hi
In Revit 2009, VAV box offset means distance between centerline of it in height and floor.
If you input same offset for duct, everything is ok and no additional fitting is needed.
But in Revit 2013, VAV box offset means distance between bottom of it and floor that makes an
additional fitting between VAV box and duct.
How can I change offset position to make it work like Revit 2009.
Aneesh
1 REPLY 1
CoreyDaun
in reply to: mars3
That would be based on the Family itself, not a setting in the program or project. If you open the Family for editing and go to the Front View (Elevation), the model should be centered vertically on a Reference Plane which is marked with "Defines Origin" and "Is Reference: Center (Elevation)" under the Reference Plane's Properties. See image of the "Out Of The Box" RMEP 2013 VAV Box Family.
⁞|⁞ Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate to further enhance these forums. Thank you!
