Revit MEP Forum
Welcome to Autodesk’s Revit MEP Forums. Share your knowledge, ask questions, and explore popular Revit MEP topics.
Using SHIFT key to draw flex duct
1 REPLY 1
1213 Views, 1 Reply
Hi All
SHIFT key does something similar to AutoCAD ortho function when I am drawing rigid ducts.
Why it doesn't work for flex ducts? Is that a way to do same for flex ducts?
Cheers,
M
1 REPLY 1
CoreyDaun
I assume that's by design - Flex Duct is not intended to be drawn with the same precision as Rigid Duct. If you are hard-pressed to attain a perfectly straight segment of Flex Duct, first draw a Detail Line and then draw the Flex Duct over it, snapping to the endpoints of the Detail Line.
Corey D.        ADSK_Logo_EE_2013.png    AutoCAD 2014 User  Revit 2014 User
⁞|⁞ Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate to further enhance these forums. Thank you!
