Revit MEP Forum
URL Parameter based on family type
2 REPLIES 2
bashworth
1189 Views, 2 Replies
Not sure if this is something wonky on my system, or if it's a shortcoming of this parameter type.
To set the scene, we have one piece of equipment, that has 6 different configurations available.  Each configuration has it's own model number, and catalog page on our company website.
I created a family for this equipment, and added the URL to the catalog as an instance parameter.  For each family type, this is a different value, since it goes to a different portion of the website.  I also have several other parameters of various types, that change value based on family type.
They all work just fine in the family editor.  I can switch between the different family types at will, and see the URL for the catalog change correctly, along with the model number, schedule values, comments, etc.
When the family is inserted into a project though, everything BUT the URL parameter works.  The URL still shows, but it only ever shows the first link I entered in for the first type I created.  All other parameters switch correctly.
I searched around, but couldnt' find anything about this being a limitation of the URL parameter type.  Is it one, or is my Revit just busted?
2 REPLIES 2
CoreyDaun
in reply to: bashworth
I quickly tested this Revit MEP 2013 (Update 2) with a couple random URL's with a catalog, and it worked as expected. Are you using this version with the current updates? Can you post your family and catalog file for us to investigate?
bashworth
in reply to: CoreyDaun
Thank you for your time on this.  Looks like it just needed some time in the corner to sit and think about what it had done.  Working correctly today.
