Hello everyone
i have a small problem on MEP revit
i attached a picture to show the problem
steps of the project
1. i created the building (Archi) on Revit Archi with all walls and roof (4 levels)
2. I linked the building on revit link into the project and make the same 4 levels as Archi
3. i started with the duct works and drew the package units
4. i created my own view template
now, on the attachments
the first frame :
you can see the 4 levels normally with the duct and units normally
on the second frame :
on level view for example (level 2) you can see the underlay is (level 1) and you can see the drawing normally
on the third frame:
when i go to Level 4 (no matter which underlay i chose) the image would be like this
there i chose underlay 2, and only thing i can see is the duct, no walls and nothing else
how can i fix this problem
Solved by abulla. Go to Solution.
Thanks for the answer, but the problem stays the same
nothing appears on level 4, i cant see the lover building
