Revit MEP Forum
Unit Conversion
3 REPLIES 3
GHASEM_ARIYANI
405 Views, 3 Replies
Unit Conversion
hi
We are in metric units.
I family got to download The unit is inches.
 Is there any way all units will convert inches to metric.
Manually takes a long time.
Please use " Accept as Solution", and give kudos as appropriate to further enhance these forums. Thank you!
3 REPLIES 3
Well, in that dialog box, set the discipline to "Common" and change the Length parameter to a metric unit.
Licensed Architect (Florida) | Freelance Instructor | Autodesk Expert Elite (on Revit) | Profile on Linkedin
Hi
I guess I do not understand.
If I change the units to meters ,Just same changes.
I want all units to metric changes, simultaneously, Like, area, volume, size pipe ...
Oh, no, that's not going to happen like that. Because each set of units has choices, preferences. Such as centimeters, milimeters, meters, etc.... How could Revit "know" all your preferences for each type of unit?
Or, simply use a metric template to start your projects.
Rail Community
