Revit MEP Forum
Under floor piping Revit MEP 2012
2 REPLIES 2
sforsberg215
1011 Views, 2 Replies
Hi
in 2011, all my underfloor piping showed up dashed and halftone. in 2012, all my underfloor piping shows up solid and dark. What is the setting and where is it to make the below ground piping dashed?
2 REPLIES 2
Under the manage tab>additional settings - check the linetype <beyond>
If my reply answers your query, please use the Accept as Solution.
Please give Kudos as appropriate to enhance the value of these forums.
Thank you!
Jrobker
in reply to: sforsberg215
This works only if your view range
Is set to bottom =0 and your view depth its below that.
"It's hardware that makes a machine fast. It's software that makes a fast machine slow."
