So I know how to color scheme ducts but how do you take it off? How do I remove the color scheme? you would think its obvious but its not...Thanks
Solved by CoreyDaun. Go to Solution.
If it is indeed a Color Scheme that is applying the color overrides, then under the View's Properties you can click the button beside "Color Scheme" and select "(none)" from the list of schemes on the left side of the following dialog.
Ah, Thanks, I had to select none in both Color Scheme and System Color Scheme. But thanks!
