I'm having a specific problem with pipe fittings and being able to continue a pipe run from a "T". I have an existing model that has a run ending with a "T" fitting. I would like to continue the run but when I try to "draw pipe" from the right click menu it does not appear. I have tried this is in plan view, 3D view, and section view but it won't work. The only workaround I've been able to find is to delete the fitting and place a new one. Then I get the option to draw a pipe from the fitting. It's the same fitting so I don't know what the problem is. I've attached a screenshot of my problem.
Thanks for any help,
Dan
Hello Dan,
Did you try changing default fitting settings. Click a pipe in properties menu click edit type > Routing Preferences Edit > Try changing your Tee family.
Hi Daniel, at first check routing preference within Revit. Revit sometimes route and connect the fitting itself while you try to connect one pipe with another pipe directly. If the pipes already stretch out from the ‘T’ shape fitting, then the ‘Draw Pipe’ option will not be visible.
