I was wondering if you can chage the template in Revit MEP 2012 to make the circuit numbers continue.
My first section is 1 thru 42. I want the second section to be 43-84.
Solved by CoreyDaun. Go to Solution.
Circuit Number is a Text Type parameter, which means that you cannot create a Calculated Value and assign a formula like "Circuit Number = 42". I don't think that you can separate the panels into two separate schedules. You will have to show all 84 circuits on a single Panel Schedule.
