Revit MEP Forum
Welcome to Autodesk’s Revit MEP Forums. Share your knowledge, ask questions, and explore popular Revit MEP topics.
Turn off pipe system in ALL views
2 REPLIES 2
KevinMurtha
1029 Views, 2 Replies
is there a way to turn off a pipe system in all views/sheets?
2 REPLIES 2
CoreyDaun
in reply to: KevinMurtha
Mass change such as that is extremely cumbersome if using anything older than Revit 2013, which has View Template dependency.
In the past, we have had to do this with work that was "removed from the scope" at the very end of the Project, with the possibility of being brought back. What we did was create a new Workset (not visible by default) and place all of those elements on that Workset.
Corey D.        ADSK_Logo_EE_2013.png    AutoCAD 2014 User  Revit 2014 User
⁞|⁞ Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate to further enhance these forums. Thank you!
Sandleaz
in reply to: CoreyDaun
Yes.  If your piping is all in another file, I am pretty sure you can unload that file.
