Revit MEP Forum
transferring MEP project from Revit 2013 to Revit 2014
2 REPLIES 2
revitworkbench
549 Views, 2 Replies
hi, I have a question transferring a Revit 2013 project to a 2014 project. I have several systems in place, and when I transfer to a Revit 2014 at least get the error message that tells me that I can't find the lookup tables. Now I know Revit 2014 has the lookup tables associated inside the family for each fitting. But in Revit 2013 tables are outside of the family. What is the procedure for transferring all Revit lookup tables so they all end up in the right spot in the right family?
2 REPLIES 2
I have been experiencing this same problem and am also looking for a "simple/easy" way to do this. I tried to reload pipe fittings from the 2014 libraries, but that does not seem to help. Anyone find a good way to correct this?
jade.l
in reply to: jamisonj1998
Please try this prosedure:
1. Open Revit 2014
2. Check the lookup table path for RVT 2014, the default path is C:\ProgramData\Autodesk\RVT 2014\Lookup Tables
3. Copy all the .csv file your fittings use to that path
4. Open the fittings to upgrade
5. Save the fittings then the lookup will be inside the family.
If you get warnings that not find the tables, it indicates that the .csv is not in the lookup table path.
jade.l
