Revit MEP Forum
Transfer Grilles
3 REPLIES 3
RJServoss
2301 Views, 3 Replies
Transfer Grilles
How do you all set up transfer grilles? When I use an air terminal family on either end of the transfer, typically air terminals have their flow set to preset, and having both ends of the system set to preset results in an error. If I use a modified end cap family to represent both ends of the transfer, I don't get any errors or warnings, but I also don't get an air terminal family that can be scheduled with the other air terminals. I have created an air terminal family with the flow configuration set to calculated for the sole purpose of handling transfers, but am not all that happy with this set up. How do you all handle transfer grilles?
3 REPLIES 3
this link may help
http://forums.augi.com/showthread.php?122490-Transfer-Grilles
let me know what do you think about it
Alaaeldin Alsahli
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
RJServoss
in reply to: RJServoss
The solution proposed in that forum is exactly how I already handle the issue. If that's the best option, then that's what I'll continue to do, but I was really hoping to hear some other options to see if there is a better way of doing it.
Rick Servoss, PE, LEED AP BD+C l Associate
LORING Consulting Engineers
1130 Connecticut Ave., NW, Suite 750, Washington, DC 20036-3915
Direct: 202.742.1464 l Main Office: 202.296.6583 l Fax: 202.296.6953
Email: rservoss@loringengineers.com l Visit us: www.loringengineers.com
[cid:image002.jpg@01CF1CF9.BD8ECAC0]
then give me time and i will try to figure out something
Alaaeldin Alsahli
