Is there a way of tagging centerline of a pipe from the floor to centreline (easy) and centreline to u/s of slab or roof fabric over
Pete
The only means of tagging the elevation is with a Spot Elevation Tag, which would only report the offset from the current or specified Level. Now, getting this to report the elevation to Pipe requires another step; change the View to Detail Level: Fine so you can see the geometry of the Pipe, and then apply the Spot Elevation Tag to the edge of it, so it essentially reports the elevation from the centerline.
