Revit MEP Forum
Title Block parameters
3 REPLIES 3
CarrieHoffman02
506 Views, 3 Replies
We are a small company so the Designed By, Drawn By, Checked By parameters for the title block are the same for every sheet. Is there a way to make these type parameters instead of instance parameters?
Thanks in advance
Carrie
3 REPLIES 3
CoreyDaun
in reply to: CarrieHoffman02
No, but I would suggest making it Text in lieu of a Label. Then you don't have to worry about the parameters at all.
⁞|⁞ Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate to further enhance these forums. Thank you!
Why not just create a schedule for batch alteration of title sheets and do all three parameters on all the sheets in one go?
If my reply answers your query, please use the Accept as Solution.
Please give Kudos as appropriate to enhance the value of these forums.
Thank you!
I have 2 types of title blocks, Electrical and Mechanical. Text seemed easiest, but I ended up figuring out what I wanted in the first place. I just have a generic label that reads the drawn by and checked by type family paramters. After I woke up and realized what I was doing it was pretty simple.
Thanks for your input
