Revit MEP
carriehall42
Message 1 of 4 (223 Views)
Title Block parameters
223 Views, 3 Replies
09-04-2012 07:00 AM
We are a small company so the Designed By, Drawn By, Checked By parameters for the title block are the same for every sheet. Is there a way to make these type parameters instead of instance parameters?
Thanks in advance
Carrie
I have 2 types of title blocks, Electrical and Mechanical. Text seemed easiest, but I ended up figuring out what I wanted in the first place. I just have a generic label that reads the drawn by and checked by type family paramters. After I woke up and realized what I was doing it was pretty simple.
Thanks for your input
CADastrophe
Message 2 of 4 (222 Views)
Re: Title Block parameters
09-04-2012 07:05 AM in reply to: carriehall42
No, but I would suggest making it Text in lieu of a Label. Then you don't have to worry about the parameters at all.
Valued Mentor
julianjameson8403
Message 3 of 4 (214 Views)
09-04-2012 08:13 AM in reply to: carriehall42
Why not just create a schedule for batch alteration of title sheets and do all three parameters on all the sheets in one go?
If my reply answers your query, please use the Accept as Solution.
Please give Kudos as appropriate to enhance the value of these forums.
Thank you!
carriehall42
Message 4 of 4 (211 Views)
09-04-2012 08:21 AM in reply to: julianjameson8403
