Revit MEP Forum
Tick marks
1 REPLY 1
auto99
248 Views, 1 Reply
Tick marks
I changed the number of Hot Conductors to 3 - number of arrows remained unchanged (1).
What does Calculated, On, Off for Tick marks do?
See attached.
1 REPLY 1
CrazedEngineer
in reply to: auto99
This one is a little odd. The best we know, is Calculated only works when it is your default, then it figures out the # of conductors you need, and/or the conductor size. On, just allows them to be shown. Off, turns the visibility off.
If you would like multiple arrow heads, all you need to do, is remove the objects from the circuit, and add them to a new circuit. But be careful or you will end up adding the device to multiple circuits, and it will take you forever to figure out where the error is .
