Revit MEP
Contributor pj
pj
Message 1 of 11 (499 Views)
Three way switches and tick marks
499 Views, 10 Replies
02-02-2012 07:29 AM
Hello.
How can I connect a three-way switch?  I know because it has something to do with tick marks, but it won't let me do that either.
CADastrophe
Message 2 of 11 (495 Views)
Re: Three way switches and tick marks
02-02-2012 07:53 AM in reply to: pj
Multiple switches cannot be connected to a Switch System. This has been a long standing issue in Revit. You can connect one of the switches to the system, but the Switch ID for additional switches must be entered manually.
Contributor pj
pj
Message 3 of 11 (493 Views)
02-02-2012 07:55 AM in reply to: CADastrophe
I'm sorry what do you mean.  Somebody told me that the three way switches has something to do with the tick marks on the wire.  But I don't know how to get the tick marks on the wire either.
Contributor pj
pj
Message 4 of 11 (486 Views)
02-02-2012 08:15 AM in reply to: pj
I don't understaind your comment before your last.
abulla
Message 5 of 11 (485 Views)
02-02-2012 08:16 AM in reply to: pj
I don't think wire tick marks would have anything to do with 3-way switching. As mentioned, the switching system in Revit is pretty broken still, the best you can do is show your switching the old fashioned way, with wires.
Contributor pj
pj
Message 6 of 11 (483 Views)
02-02-2012 08:20 AM in reply to: abulla
So there no way to get the tick marks on the wire.
I tried to turn them off/on on the properties.  But there's no way?
Dang :smileymad:
abulla
Message 7 of 11 (481 Views)
02-02-2012 08:22 AM in reply to: pj
In your Electrical Settings under Wiring, you have to specify what tick marks you want to use for hot, neutral, and ground (make sure they're loaded, Annotations->Tick Marks).
CADastrophe
Message 8 of 11 (479 Views)
02-02-2012 08:26 AM in reply to: pj
Can you post an image of what you ultimately wish to accomplish?
Contributor pj
pj
Message 9 of 11 (474 Views)
02-02-2012 08:38 AM in reply to: CADastrophe
OK
The first picture shows the wiring without tick marks.
The second picture shows the properties that I'm trying to make the wiring have tickmarks.  Under tick marks shows ON.
The thrid picture shows the properties that I'm trying to make the wiring have tickmarks.  Under tick marks shows CALCUATING.
The last picture shows the properties that I'm trying to make the wiring have tickmarks.  Under tick marks shows OFF.
I hope this helps you to help me.
Thank you.
CADastrophe
Message 10 of 11 (463 Views)
02-02-2012 10:37 AM in reply to: pj
OK. So it's just a tick mark issue - it looks like they're not loaded. Go to Insert Tab » Load Family and browse to Annotations/TickMarks and select all of the files shown and click 'OK'. Then go to Manage Tab » MEP Settings » Electrical Settings. Select "Wiring" in the left panel and you will see the Tick Mark settings. Change these to the appropriate value.
