Revit MEP Forum
Welcome to Autodesk’s Revit MEP Forums. Share your knowledge, ask questions, and explore popular Revit MEP topics.
the ribbon can not change
3 REPLIES 3
479 Views, 3 Replies
Dear All
I am using the Revit Mep 2012. if I create the pipe the ribbon can change in fisrt time but create the sprinkler or slab the right hand side ribbon no change in other commond. please help
thank you
Samy
3 REPLIES 3
CoreyDaun
My guess is that this started after Revit 2014 was installed in your computer, correct? If so, this is a known bug that affects the contextual tab on the Ribbon for both 2012 and 2013. If you "cycle" the Ribbon display (the gray "up-arrow" button toward the left), it will refresh the correct contents of the tab.
I don't know if there is a direct fix for Revit 2012, but I would recommend searching the Revit Architecture board for a solution.
> Revit 2013 Ribbon Issue <
Corey D.        ADSK_Logo_EE_2013.png    AutoCAD 2014 User  Revit 2014 User
⁞|⁞ Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate to further enhance these forums. Thank you!
tkaak
thank you all
