Dear All
I am using the Revit Mep 2012. if I create the pipe the ribbon can change in fisrt time but create the sprinkler or slab the right hand side ribbon no change in other commond. please help
thank you
Samy
My guess is that this started after Revit 2014 was installed in your computer, correct? If so, this is a known bug that affects the contextual tab on the Ribbon for both 2012 and 2013. If you "cycle" the Ribbon display (the gray "up-arrow" button toward the left), it will refresh the correct contents of the tab.
I don't know if there is a direct fix for Revit 2012, but I would recommend searching the Revit Architecture board for a solution.
You will need to install Update 2 and the .net hotfix.
Update 2:
.net 4.5 hotfix:
Greetz,
Theo
