Revit MEP Forum
Welcome to Autodesk’s Revit MEP Forums. Share your knowledge, ask questions, and explore popular Revit MEP topics.
Text formula
2 REPLIES 2
tbrown6608
1501 Views, 2 Replies
Text formula
I have been trying to get this to work:
if(Offset = "Left", 1'-0", if(Offset = "Right", 3'-0", if(Offset = "Center", 2'-0", 2'-0")))
Offset is a text parameter, I am apply this formula to a length parameter. Revit tells me "Improper use of boolean expression" I have also tried using commas instead of equals signs and when I do that Revit tells me "Bad IF-statement format. It should be IF(<boolean>, <result-if-true>, <result-if-false>)." Can someone please tell me what I am doing wrong?
2 REPLIES 2
CoreyDaun
in reply to: tbrown6608
You're not doing anything wrong - Revit does not understand or permit a Text parameter to be used in a conditional statement. There is A LOT of improvement needed with the formulas. I would be happy to help you find workarounds if you wish! I've had to do so many times myself...
Corey D.        ADSK_Logo_EE_2013.png    AutoCAD 2014 User  Revit 2014 User
⁞|⁞ Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate to further enhance these forums. Thank you!
tbrown6608
in reply to: CoreyDaun
Thank you. I will be able to figure out a work around for this it will just require a few more parameters to do what I need to do.
