Revit MEP
Active Contributor
tbrown6608
Message 1 of 3 (561 Views)
Text formula
561 Views, 2 Replies
06-14-2012 01:54 PM
I have been trying to get this to work:
if(Offset = "Left", 1'-0", if(Offset = "Right", 3'-0", if(Offset = "Center", 2'-0", 2'-0")))
Offset is a text parameter, I am apply this formula to a length parameter. Revit tells me "Improper use of boolean expression" I have also tried using commas instead of equals signs and when I do that Revit tells me "Bad IF-statement format. It should be IF(<boolean>, <result-if-true>, <result-if-false>)." Can someone please tell me what I am doing wrong?
You're not doing anything wrong - Revit does not understand or permit a Text parameter to be used in a conditional statement. There is A LOT of improvement needed with the formulas. I would be happy to help you find workarounds if you wish! I've had to do so many times myself...
CADastrophe
Message 2 of 3 (557 Views)
Re: Text formula
06-14-2012 02:09 PM in reply to: tbrown6608
Active Contributor
tbrown6608
Message 3 of 3 (555 Views)
Re: Text formula
06-14-2012 02:14 PM in reply to: CADastrophe
Thank you. I will be able to figure out a work around for this it will just require a few more parameters to do what I need to do.
